Will on send out blank pages when I pring
SOURCE: HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
SOURCE: prints extra blank page for every one page of printed material BEWARE SPAM NUMBER 1-800-532-4187
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page
after each print page.
I went into the Control Panel/Printers - Right
click on the HP Photosmart 7200 series icon and choose delete. Don't
worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
SOURCE: Blank sheet before each printed page
Here's a simple solution. It's easy! Instead of it being the C7280 - it's the C7250 - should be the same driver however. Good Luck!
SOURCE: hp 1320 prints blank LOSER SPAM ALERT 1-800-532-4187
My HP 1320 printer is printing blank pages and it will not even print test pages etc
