SOURCE: dacor oven ECPS127S will not heat after self clean
the problem was fixed by opening the panel between the oven cavity and the touch panel just behinf the door. you can look through the grill but to trip the reset you must unscrew the panel. you will find the reset back behind the wires Looks a red button nestled on top not very open but it should be there> i do have to say i found a step by step description on this site. but right now i can't tell you who exactly he was.
SOURCE: dacor convection oven is displaying off mode and will not go on
Press the "Cancel/Secure" until the display clears.
SOURCE: Our Dacor ECS130SBK convection oven no longer
The element is probably failed. Using an oven in this manner (turned on with the door open) is not good.
The element is replaceable, and will require some electrical tests to confirm the failure.
SOURCE: ECS227 Epicure Electric Double Oven: I have a Dacor model # CPD227R double convection o...
replace touch pad
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
