Bachmann IndustriesINPUT: 120 VAC 60Hz. OUTPUT: AC 16V 1000mA ... After the track connections are complete, plug the Wall Pack Power Supply into a standard 110 ... If your Control Center does not power up as shown here, disconnect it from the Wall Pack ...
Bachmann IndustriesNOT RECOMMENDED FOR CHILDREN UNDER 14 YEARS OF AGE. ... The E-Z Command® 5 Amp Power Booster provides extra power to the track so ... locomotives on our N, HO, OO, S, O, On30, or Large Scale layout. ... Make sure the smaller plug end is connected to the DCC input jack marked DCC IN (figure 2) on the.
1: make sure all track connections are tight. 2: clean the track using a Green 3M scratch pad or a track eraser. 3: clean your wheels, some people use smoke fluid on a cloth, I use alcohol prep pads,. A track eraser can also be used. there are commercial wire brush cleaners that connect to your power source.
hi did you find the instructions, i have the same problem, have no instructions and trying to put it together by looking at a picture. if you have the instructions could you please try and email me a copy if it is at all possible. My email address is [email protected]
If it worked on Windows 7, it will definitely work with Windows Vista The only thing you need to check is if its Vista 32-bit or 64-bit - the latter is known to be not compatible with a lot of software.
This is not true. There are a couple of things you can try. One is to try installing the software in XP Compatability mode. Run the install as an administrator.
If that fails, you can certainly get it to run if you use some free virtualization software (VM) to create an instance of Windows 98 or Windows 2000 on your computer and then install Thomas inside this virtual machine.
