SOURCE: HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
SOURCE: hp laserjet 4200 printer- how to find the current ip address?
To have an IP address for the printer you must either have a HP4200n or install a Jetdirect card into the printer. The Jetdirect or "N" version of the printer with the built in Jetdirect holds the network IP address. Subnet Mask, Gateway Derfault and handles the networking functions. If you have a 4200n or Jetdirect installed it will print out on the configuration page.
The standard HP 4200 doesn't have the networking capability without adding the card. In the event that you have a card installed and its not recognizing the card on the configutation page it may be bad. The HP 615n cards are known to have burn out issues. If you have to install a card to upgrade your printer, I recommend a HP 620n or better to get around the known bad issues with the 615n cards.
SOURCE: HP LASERJET 3055 Manual IP Address not saving
Switch off the printer and press * & enter key together &switch on wait till you see " permanent storage int"
then release button your printer comes back to original defaults
then re-configure printer as you require
Murali,
PALLAVI INFOTECH
BANGALORE
SOURCE: how to i configure the
Hello, When you first install the printer onto the Network it will automatically find an IP Address, this is called "DHCP". In order to change the IP Address the printer needs to be setup as what is known as "STATIC". You can do this in in a couple of ways 1) Type the IP Adrees into an internet explorer Browser, this should open up the printers EWS (embedded Web Browser) if it opens click on the networking tab - Chnge the IP Address , set DHCP to "OFF"and click Apply. 2) From the printers control panel - push the "MENU" button and scroll down to the "CONFIGURE DEVICE" to "I/O" to "EMBEDDED JETDIRECT" Withi the TCIP setting you are able to change the printers IP Address
SOURCE: how do i set the
First let me state that the network cards on these printers are notoriously bad and fail very often. Before attempting any settings, use the arrow keys to bring up the information menu and then printer a configuration. If you have a network cable plugged in then the configuraiton page will print both the basic pirnter configuration page and the Jet Direct status pages which will show the currently set network information. If only one page pirnts then the card is not working, if three pages print the card is working and you will be able to follow the instructions below.
Press the menu button and then use the up and down arrow buttons until "configure device" is shown and press the checkmark. Use the up and down arrows until display reads "EIO" jet direct menu then follow these menu options
Arrow down until display reads TCPip press check.
Arrow down until it reads enable, press checkmark and change option to yes, press checkmark.
Next arrow down to config method press check and then choose DHCP or manual and press check. If you have a router it will automatically assgin an address to your printer when you set it for DHCP, if not, you will need to select manual and then manually input IP address, subnet and gateway.
Once you select manual you will have the option to input the IP address, subnet and gateway using the arrow keys and the checkmark.
