is it an inverter fridge which saves on energy. that makes a high pitch sound. i recently fell into the same trap. if it has a clock set the time so its more inclined to make those noises when you are asleep.
In your manual it will tell you what grade of slope the the Scooter will safely go up. If the slope is too great the motor will have too much of a load, and the controller will a over current situation and shut down. squealing noise may have to do with transaxle its self than the Motor Brake. The gears in the transaxle could make the squeal noise.
Amigo Scooter Oxygen Tank Holder Light flash key turned ...
www.fixya.com > ... > Amigo > Amigo Scooter Oxygen Tank Holder
... key on my phoenix 3 scooter the red light flashes 5 times and the scooter will ...scooter wont move,although on the little speedo there is a red light flashing on ... ...light is flashing when the key is turned on. the scooter does not move at all ... flash up and down the console light and you at this point have to turn the key off ...
Oct 8, 2014 - my pharmore wizard diagnostic light flashes 9 times and my scooterdoes not go, can someone help me please - Mobility Scooters question. ... Have no manual for pharmore 4 wheeled wizzard light on but wont move ... Why did it stop working suddenly and is blinking console light in 5-blink sequence?
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
With a piece of wood or plastic hit the flyback with the monitor turned on. If you note some change in the noise. Replace the flyback. Normally, it is the cause of the noise.
In electronic equipment, it is often a capacitor (One of those electronic thingies in the control box.) that begins to fail and results in a high pitch noise (Oscillation) that will drive you crazy. They still operate correctly but over time they will totally fail. Unfortunately this may require a technician to assist. Happy scooting. Regards Chris… [email protected]
