SOURCE: Color registration on Canon GL2: purple recorded as blue
I have the same problem on my Canon XH-A1 and sony TRV33. I wonder if this problem applies to all camcorders?
SOURCE: canon gl2 camcorder, how do i download my film to vista
I'm having the same problem. I don't have the disks with the camcorder and Vista is not recognizing nor seeing the camcorder. I'm going to try to download Zoombrowser and see if that makes it work.
SOURCE: Flashing red symbol on screen - not 'no cassette loaded' symbol.
I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
SOURCE: Image wont come up on screen and its flashing me
No. The power converter inside the camera is damaged some how. It says the battery needs charging because power cannot get to the main circuit - it needs to be taken apart and isolate the crack or open contacts.
