If internet explorer is not working properly then contact Customer service number to solve issues via technical expert. Read More : http://www.dialtollfreenumber.com/internet-explorer-customer-service
SOURCE: WWW.SPYDOMAINS.COM HAS BLOCKED MY INTERNET EXPLORER
download google chrome(search it up on google). its much better
SOURCE: when ever i try to go to www.arcadeprehacks.com
interesting
few things to try and troubleshoot
1. get firefox installed and try to see if the same problem takes place when using firefox, use another computer when problem appears and to test if the website is down.
2. have you tried clearing internet cache, go into internet explorer's tools, go to options and delete temp files, cookies, form data and other items and attempt to try again.
3. do you have any applications installed that monitors your webbrosing from security reasons? try to check the configuration of such application and test accordingly (check antivirus suite or other web monitors you have installed).
4. some viruses and other malware may hijack your browser, installed, update and run deep scans, this step takes time and it takes more than one tool to get this completed.
if you need more details feel free to post back with your findings!
3.
SOURCE: Acessing AOL web base email problems with internet explorer 8
you can download google chrome for free and set it as the default browser
SOURCE: When I go to internet explorer my home page
check that u did not set ur home page to black from tool internet options, run reginout cleaner may fix it
SOURCE: how to fix internet explorer issues
go to tools >> internet option >> general tab >> delete cookies
if thats not enough go to advance tab and restore advanced setting
still persist with problem reinstall iexplorer
Close any Internet Explorer or Windows Explorer windows that are currently
open.
Click the Tools button, and then click Internet Options.
Click the Advanced tab, and then click Reset.
Select the Delete personal settings check
box if you would like to remove browsing history, search providers,
Accelerators, home pages, and InPrivate Filtering data.
In the Reset Internet Explorer Settings
dialog box, click Reset.
When Internet Explorer finishes restoring the settings, click
Close, and then click OK.
Close Internet Explorer.
Your changes will take effect the next time you open Internet
Explorer.
If you close all visible windows, but still get an error message
when trying to reset, you might have programs running that are not visible.
Restart Windows, open Internet Explorer, and
try resetting again.
To back up your home page or home page set before resetting
Internet Explorer defaults, see Back up your
home page or home page tabs.
If any of the categories fail to reset, it is because Internet
Explorer could not access a file or registry setting. This can be caused by
insufficient security privileges, files or settings being used by another
program, or low memory or high CPU usage. You can either continue to use
Internet Explorer without restoring these settings, or restart your computer and
try to reset again.
If you are using Internet Explorer on a server and have turned off
Enhanced Security Configuration or hardening (stronger security settings for use
on servers), reset will go to client-level security. You must reinstall
hardening if you want the increased security level. For more information on
Enhanced Security Configuration, see Enhanced Security
Configuration for Internet Explorer online.
To re-enable add-ons, see Internet
Explorer add-ons: frequently asked questions.
