My outdoor temperature is showing - -.- Tried to do battery changes, still will not register
Http://www.lacrossetechnology.com/media/catalog/product/w/s/ws-9611u-it.pdf Here is the method used to set up the outdoor transmitter with the base station
Testimonial: "Still not working after correctly changing batteries."
SOURCE: My Nexxtech wireless weather station
You must move the remote sensor close to the base unit to reset it and it will work fine. After it shows the temp then you can move it back to its location. thanks for asking at Fixya.com.
SOURCE: The outdoor temperature & hygrometer
Hi Walter,
I found this in the manual, simply pressing the RESET button won't start communication again. Try this:
Your main unit displays current, minimum, and
maximum temperature and humidity readings
collected by the remote sensor and main unit.
Outdoor data is collected and displayed every
40 seconds and indoor data is collected and
displayed every 10 seconds.
The red LED flashes whenever the sensor
transmits an RF signal to the receiver.
select sensor or use auto scan
• Press CHANNEL to switch between
sensors 1-3.
• To auto-scan between sensors, press and hold
CHANNEL for 2 seconds. Each sensor's data
will be displayed for 3 seconds. To end autoscan,
press CHANNEL or MEMORY.
• Press and hold CHANNEL and MEMORY
simultaneously to search for remote sensors.
resetting the system
The RESET buttons are located on the back of the
main unit and sensor. Use a pointed subject to
press RESET when you change the batteries and
whenever the system malfunctions.
sometimes you have to sync the units again, look for a button on the indoor or outdoor unit that says 'sync' or 'connect'
SOURCE: i put new batteries into both units, the indoor
Sometimes the RF frequency from the outside transmitter loses contact with the clock's frequency ( it has happened to me only twice in 6 years ), and then the outside temp will not show. Simple solution to fix this is: Take down the outside transmitter and the internally mounted clock. Remove batteries from both. Wait about 10 mts. First install batteries in the transmitter, then after about 30 seconds, install batteries in the clock. In about 5 mts, you will find the clock showing the external temp like before.
