Singer 7462 Mechanical Sewing Machine Logo
marilyz rivera Posted on Sep 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Singer 7462 wing head dont spin. when i tried to put in thread to the bobbin
R.A. Ellis
Level 3:
  • Singer Master 12,731 Answers
  • Posted on Sep 20, 2016
R.A. Ellis
Singer Master
Level 3:
Answers
12731
Questions
Helped
2613044
Points
59176
How do i take the casing off a singer sewing the confidence 7463
Are you sure it needs a timing adjust? Please describe your observation of hook, needle and top thread.
Suggest you thoroughly clean the bobbin case and race area. Then lubricate the race as per instructions.
See following link for copy of a 7462 manual. Should be close enough for this purpose.
https://www.manualslib.com/manual/461365/Singer-7462.html?page=64#manual
The download is free of charge and no registration required. You may have to complete an "im not a robot" challenge. If you get into a page requesting registration, a click bait got you... exit an try again.)
1helpful
Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
4helpful
Can't pick up bobbin thread when I do manage to get the bobbin thread through . the machine works away making the holes but not sewing Singer 7462
Unfortunatlly if it will not pick up thread, it is possibly out of time. But before you go changing the timing, make certain it is threaded correctly, the bobbin is threaded correctly. If they are all good see my tip on time a sewing machine.
How do i thread my bobbin on my singer merritt 4530
Run the thread around the little silver knob on the top of the machine to the bobbin threader on the top right. Wrap the thread clockwise around the bobbin a few times and then pull the bobbin threader toward the silver bar. If you put your hand on the crank wheel, you will feel a place for your finger to set. Push there and the center of the crank wheel will sideways allowing you to thread the bobbin when you press the pedal. I'm sure my terminology doesn't make any sense.
1helpful
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Sewing machine dressmaker model 300z
i think you have not looped the thread around the tension on the top before putting it onto the bobbin. you need to wrap the thread in a circle around the sphere near the regualr threading lines.
Singer model 7462 sewing machine
Sounds like there is thread around the bobbin winder shaft and the machine is unable to continue winding, needs stripping and looking at. This is not something you should attempt yourself unless you know what you are doing. A reasonable sewing machine tech should be able to sort it out in a few minutes.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
