Azend Group MDP 1008 Maxmade Portable Dvd Player 10.1in High Definitio Logo
Erica Fleming Posted on Sep 20, 2016
How to adjust the volume without the remote - Azend Group MDP 1008 Maxmade Portable Dvd Player 10.1in High Definitio
Dan Bruno
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Sep 20, 2016
Dan Bruno
Contributor
Level 1:
New Friend:
Answers
21
Questions
Helped
5673
Points
59
If there isn't a physical knob or other "manual" adjustment on the unit itself, for adjusting a parameter available on the remote (such as volume), then the remote is the only way, and you'll need it to fully operate your DVD player.
If it's any consolation, there are many other "remote-dependent" devices made today, unlike yesterday, when the opposite was the case, where the remote controlled only a portion of available functions, and all of them were manually available on the unit.
Would it be the Amplifier or my remote control producing this problem?
Dirty contacts on the buttons. Take apart and use electrical switch cleaner.
Is there a way to adjust the speaker output volume on a Dennon av 800 without the remote
If you look to the right of the receiver there is a knob that says master volume. Turn the knob in order to change the volume. It shouldn't matter what sound mode you are in.
How to you go to sound on a akai without remote
do you mean how to access sound adjustment with out remote.did you tried to use the volume adjustment button in the tv panel.
2helpful
Tv is stuck on aux
Push the "menu"button on the front of the unit. That will get you into the menus to adjust any setting, like caption, language (but that one is tricky if yours happenend to be set to a language you couldn't understand :P), brightness settings and the such are there too. The one you are looking for is "input", change THAT setting. with either volume up/down +/-, or channel up/down (+) (-). In the menu, change the "input" selection to cable or whatever you are trying to watch on the tv.
Hope this helped some, if so, please rate, thank you!
Channel setup
V-Chip Setup
Caption
ect.
Using the Volume + and - along with the Channel up (+) and down(- ) key's, will give you all the adjustments you may need without a remote control.key's, will give you all the adjustments you may need without a remote control.
Samsung remote volume control returns to max sound on its own
dear, you have to check your +button whether it is holp the egde of your remote, open your remote and clean, and also check a button on tv for +volume button. there is a pulse condition sensed by the volume control stage. if you can manage do it, or take it to a technician.
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
1helpful
2answers
Volume knob
I contacted Jensen and got a real soluton without paying you anything....and it didn't cost me one dime!!!!
Universal cable company remote control codes
brighthouse remote code for panasonic amolifier to adjust volume
Using Without WIRED REMOTE
All I could suggest is run the decoder off the line-out of your soundcard, then regardless of what the volume or power setting is to your speakers, the signal will still come through?
Tony
Top Azend Group Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Azend Group Televison and Video Expert? Answer questions, earn points and help others
