What size/capacity USB stick? Some machines will not read the larger ones.
Testimonial: "I have noticed it is a 16gb so I believe it is 2 large for the machine to read, but it did try to read in the first place. I think the USB reader is still not working as well as it should as I have a floppy disc drive with usb to read the discs and this does not work on all discs that my mum used. The machine is approx 10 yrs old and was not used for approx 6 yrs as I was not game enough to use it. Thanks for the info!"
SOURCE: can I transfer a pattern from brother 4000d machine to usb
Welcome to Fix Ya!
Are you trying to transfer a built-in pattern from your machine to a USB flash drive? I'm not sure if built-in designs can be transferred in their original form. You might try editing the design a bit, save it to a memory space, then save it to the memory stick. If you have a manual, it should describe how to move designs from your embroidery machine to your computer, and vice versa.
If you are other readers have time to rate my answer, you'll help me become a better expert. If you can give me more specific information about what happens when you try to upload a design from your machine, and whether you have a manual feel free to leave a comment and I'll check back with you.
Cheers, Ginny
Ch
SOURCE: My Brother Innovis 4000D will no longer
if the machine is less then 5 years old and you have a proof of purchase it is covered under warr. only the labor is not still covered. It will need a new board to fix the problem
Testimonial: "Well, You pointed me in the right direction. Thankx for the prompt feedback."
SOURCE: brother innovis 4000D seems frozen, screen works but willnot lower needle
Try sewvacdoctor.com for list of possible remedies. Jimmy
try changing the needle
clean under the needle plate & in the bobbin area for loose threads or lint
rethread the machine top & bobbin
Testimonial: "Thanks so much for the help :)"
