SOURCE: Error codes
This code is suggesting a motor related fault. Check the brushes in the first instance.
SOURCE: the washeer machine give a error code E4
A code of E4 means that there is to much suds or the pump is blocked. use less detergent and get detergent with he in the title. turn to off and try to restart the drain to correct problem.
You will find the code in the manual. If you do not have let me know I will send you one here.
Good Luck And Please Rate FixYa!
SOURCE: i have a stirling washing machine xqb90-701clps
my machines not washing properly i think.. The wash is complete but theres still powder on the clothes.. What do i do to solve it?????
SOURCE: error code f h
The FH code in the owners manual talks of a water supply.The F/H code means the unit isn't detecting water fill at the flowmeter. The flow-meter sits just in front of inlet valve and is attached via a hose, and off to the left of the CCU. If your washer is filling ok, check the wiring from the flow meter to the control board; I've seen this harness jiggle loose and cause problems. check figure for flow-meter
location.
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
1.Make sure that both valves at the water source(s) are turned on all the way.
2.Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3.Verify inlet valve operation
1.Verify Drain pump operation
2.Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
