Cameras Logo
Vjdgjsjasd Posted on Sep 19, 2016
How can i change the fuking language of japan to english with hitachi c21-fl21f
5 Related Answers
A
Anonymous
  • Posted on Apr 06, 2008
SOURCE: Chaging the language to English
turn on the camera, then go on menu right?
go to setup, then scroll down until you see language on the right side.then click on the right arrow (to highlight 'language'),and click on in once again to change te language, click on english, and wahhla!9 oh, and i 'think' click on ok after that. :)
Anonymous
  • 34 Answers
  • Posted on May 01, 2009
SOURCE: LANGUAGE SETTING JAPANESE TO ENGLISH
Hello analyn
There may be a simple fix to this problem.
Find a friend that has a cybershot of the same model as your own. In their camera, open the menu and navigate to the language setting. While you do this count how many times you press the button. Example:
Menu
-camera settings 1
-program 2
-personal settings 3 press ok
personal settings
-storage type 1
-date and time 2
-language 3 press ok
language
-spanish 1
-english 2 press ok
-japanese
Although the language is different, the number of spaces should be the same, so even though you can't read it to change the language, you should be able to count it out. Or if you are lucky you may have a Japanese friend who can read it.
Hope this helps
-Chris
Anonymous
  • Posted on Jun 27, 2009
SOURCE: request for the english langage
Hello sir i have fujifilm finepix 4500 digital camera how i can english in english language
Anonymous
  • Posted on Sep 21, 2010
SOURCE: How to switch language on japanese bought sony dsc-wx1 cybershot?
I bought a camera in Japan (Sony Cybershot DSC-WX1) and now it seems that i can't change the language from japanese to english. If i select (can't read it but with the help of the english digital guide i think i have the right menu)change language, there seems to be only one language available. -japanese- How do I solve this?
Anonymous
  • 1177 Answers
  • Posted on Jan 27, 2011
SOURCE: My question: I bout a
The language setting is the last option on the setup menu. Press menu, then right side of the rocker for setup, then up for language, then right to set and up or down to select English, then menu to exit.
2answers
CHANGE LANGUAGE
you can set the laguage on the remote control.go to menu and try to find the language set up menu...
My remote is brokend and as soon as i press menu on the tv you will see a lock
sounds like parental controls are engaged, which locks out direct menu control, requiring a 'pin' entered from the remote to grant access. Get a new remote.
Owners manual
have you tride changing it in your cable box
HOW DO I CHANGE MY hITACHI TV LANGUAGE INTO ENGLISH
I want my hatachi tv c21-fl21m factory code plllzzzzzzzz
26helpful
3answers
1helpful
Removing the Child lock when remote doesn't work
CHILD LOCK CAN ONLY BE REMOVED IF REMOTE IS NOT WORKING, OPEN YOUR TV AND CHECK FOR 8 PIN INTERGRATED IC..24C04..ANY NUMBERS LIKLY TO BE FOUND AND REPALCE WITH THE SAME NUMBER, IT WILL WORK
My hitachi c21.fl20f language is chinese and i want it in english
Ask at http://chinamanuals.com - they are specialized on english manuals for chinese import gadgets.
Top Hitachi Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Hitachi Camera Expert? Answer questions, earn points and help others
