Televison & Video Logo
m
marlene cruickshank Posted on Sep 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I copy from vcr to dvd without aremote
Vinho Xie
Level 3:
Genius:
  • Televison & ... Master 1,419 Answers
  • Posted on Sep 02, 2021
Vinho Xie
Level 3:
Genius:
Answers
1419
Questions
0
Helped
413748
Points
4431
The Direct, At-Home Way: Use a DVD Recorder
If you want to save some cash and are willing to put in a minimal amount of work, a DVD Recorder is an easy do-it-yourself option. It allows you to pop in a VHS (you will need a VCR for this), insert a DVD-R disc, and press record to dub the video over. There's a lot of waiting involved, but it isn't a ton of active work, and it's much cheaper than using a professional service if you have a lot of tapes.
You can grab a separate DVD recorder that plugs into your VCR with analog cables, but I recommend using a VCR/DVD combo unit if you don't have one already. These are becoming rarer in stores, but you can grab used ones on eBay for between $50 and $150 depending on the model (I actually found one at my local e-waste center for a measly five bucks).
BTW, if you want to play DVD on PC, you'd better make use of some DVD player. Here are some free DVD player FYI.
Cade Song
Level 2:
Sergeant:
Habit-Forming:
  • Televison & ... Expert 125 Answers
  • Posted on Jul 05, 2018
Cade Song
Level 2:
Sergeant:
Habit-Forming:
Answers
125
Questions
0
Helped
38761
Points
791
You can refer to this VHS to DVD tutorial, it's got specific steps of how to do it there. VHS to DVD Tutorial How Can You Convert VHS to DVD at Home
Annielee
Level 2:
Novelist:
  • Expert 71 Answers
  • Posted on Sep 19, 2016
Annielee
Expert
Level 2:
Novelist:
Answers
71
Questions
0
Helped
9026
Points
443
As for such situation, you may need a DVD Creator.
Leawo DVD Creator can convert video and burn video to DVD-5/DVD-9 content with abundant DIY features to customize DVD movies.
  • Create DVD-5/DVD-9 disc, folder or ISO image files from recorded videos, online videos and other videos;
  • Preset 40+ disc menu and template models for DVD burning, even allow DIY disc menu and template;
  • Convert 2D video to both 3D and 2D DVD movies, with 6 different 3D effects available for choice;
  • Practical and user-friendly video editing features to get customized DVD movies;
  • Fast DVD burning via Intel Quick Sync accelerating technology;
Besides, if it is necessary, you can also use Leawo DVD Copy which can help you copy and backup DVD discs, DVD folders and ISO Image Files to PC or disc, with marvelous bonus features.
  • Copy DVD to DVD disc, file folder and ISO Image File with no quality loss;
  • 1:1 disc to disc duplication while retain original disc quality;
  • Copy DVD-9 to DVD-9, DVD-5 to DVD-5, and even compress DVD-9 to DVD-5 with high quality;
  • Copy DVD contents in different copy modes: Full Movie, Main Movie and Custom Mode;
  • Copy and backup CSS-DVD discs and common DVD discs easily;
Easy to Convert Any Videos to DVD Disc Leawo DVD Copy Software Clone Copy DVD movie to DVD RW disc or hard drive...
1helpful
2answers
Want to unlock region codes on my Samsung vcr/dvd recorder model no dvd-vr375 so I can record here and it can be played in Canada
Do the following step to make your DVD player region free..
1.Turn machine on without disc inside
2.Press menu button
3.Enter region code (See below for list)
4.A highlighted 'region area number' will appear in the upper left corner (some players)
5.Press 9 to change the region number to multi-regional
6.Turn DVD off (remove power from mains)
next time when u power on the DVD ,it will be region free.
region 1 - 29334
2 - 38767 or, 5 7 5 3 8
3 - 56732
4 - 76884
5 - 53814
6 - 24462
ok
2answers
Dvd player
hi there,
the Built-in DVD player only runs Region 1, if this is not bought in UK, i'm afraid it cannot play DVD's from UK.
1helpful
2answers
I just bought a Magnavox ZV450MW8A DVD/VCR Recorder. It has recording capabilities on both the DVD and VCR components but can you tell me if I can use it to record FROM the VCR directly onto the DVD? This...
Yes, you can, I have this unit and have actually copied a dvd to a vhs and then copied back to a dvd as I wanted a dvd copy to give a friend. The directions in the book are really quite simple. They tell you how to set the vhs to the spot where you want to start copying, etc.
I have not yet tried copying my family vhs tapes, but don't see a problem, just a big project. Good luck.
2answers
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
2helpful
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
One touch copying
Of course, press copy, the screen should ask what record speed, then press copy again. This should solve your problem.
4answers
VHS to DVD recording
Yes, just turn off the tv.
Walt
2answers
How can I record from the vcr to the dvd
on a combo unit ,insert the vcr tape and then put a blank dvd r /rw in to unit , you should then press rec button and records to dvd.
note you cant copy proteceted tapes due to the macrovision
Recording from VCR to HDD
The VCR tape contains a copy inhibitor along it's length, so cannot be copied. the only way to make a copy is to use a truly analog route, without any copyright checking getting in the way. I think this is mentioned in the manual.
3answers
Sansui vrdvd4005what format does it record in
orion that makes this unit says that there are no parts left for repair of this unit.fyi
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
