Video Cameras Logo
Damian Brown Posted on Sep 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot get my Panasonic HDC TM 350 external mic to work External microphone will not work - I need some support to make this work
Voros101
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 132 Answers
  • Posted on Oct 09, 2016
Voros101
Expert
Level 2:
New Friend:
Cheetah:
Answers
132
Questions
0
Helped
48114
Points
181
Does the mike connector fits the camera?? Tthe mikes cable are in good shape?? Try another mike. Is the receiving plug in good condition on the camera??
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on May 12, 2006
SOURCE: Canon XM2 -Burned main-board
im wondering why it cant be repaired down to componet level as if the servicer has a schematic its probaly not more then a cap a diode or both snf msybr sa resistor as they do have a protection curcuit on thes camcorders that wount let it distroy the Board Maybe you need another servicer??? Im not sure of your queistion on the adaptor But im sure that if you look in your owners manual it will assist you in where to call to get or buy accessorys. Good luck
Anonymous
  • 38 Answers
  • Posted on Nov 09, 2007
SOURCE: Sound recording with external microphone
An instruction manual is available for download at www.canon.com
Your camera, according to the manual, has a single input for microphones, and in the internal menu, AUDIO DUB has to be set to MIC. IN. when using an add-on microphone. An MA-300 hot-shoe microphone accessory can be used, and then the input controls would be on this device, not the camera. Your camera can also record in two different audio qualities: 16-bit two channel or 12-bit four channel. If you are using an accessory you may need to select 12-bit in the internal setup menu in order to have enough channels to add on the additional microphone(s).
Finally, and hopefully not, the camera may have an internal hardware problem, and so would need to be serviced.
Anonymous
  • Posted on Jan 29, 2008
SOURCE: microphone
For microphones with a 3.5 mm miniplug you can use a plug-in at the front of the camera. There is a little plastic cover over the hole under the word "MIC". I would call this an emergency solution because for most recording purposes you would want a microphone with XLR connectors.
This camcorder comes with an external shotgun condenser mic and XLR adaptor. If you have the operating instructions that come with the camera, you can turn to page 29 where there is a description of how to install the supplied external microphone.
When you slip the hot shoe plug of the XLR adaptor into the intelligent accessory shoe, the internal microphone is by-passed. In case you do not have the operating instructions you can download them from the Sony manual site.
http://esupport.sony.com/perl/select-system.pl
Put briefly, Attach the XLR adaptor to the accessory shoe on the top front of the camcorder and tighten the screw of the adaptor. Connect the hot shoe plug of the SLR adaptor to the intelligent accessory shoe of the camcorder, located behind the adaptor screw. When you push the hot shoe plug into place you should hear a click. Sometimes you have to use a little strength to get it correctly seated.
I hope this helps.
Anonymous
  • Posted on Oct 11, 2009
SOURCE: JVC Everio GZ HD-40's external microphone problem
I have the GZ-HD40 and have tested the scenario below.
The problem is that the Microphones you are using are Mono, not Stereo. If you look at the plug on the end of your microphone you will see it has only two connections, the screen and the tip. For a Stereo mic it needs three connections screen, sleeve and tip, much like your headphone jack.
I know this is going to sound a bit nuts but use a set of head phones as a microphone. You will notice the left speaker acts as the left mic and the right speaker as the right mic.
Use microphone JVC MZ-V8 Stereo microphone and you will see that it has the three connectors as I have stated above.
Hope this helps.
Anonymous
  • 175 Answers
  • Posted on Feb 26, 2010
SOURCE: what do i plug my external microphone into on the
Thanks for clarifying the model. According to the user manual, there is no facility for "sound in" on your camcorder. ALL SOUND recorded is via the stereo microphone at the front of the camera.
The AV socket is for a feed out only.
However, there are a couple of things you can do to improve your sound.....
You have the option (via menu setting) to reduce the "wind cut" (extraneous noise of the wind blowing across the
microphone).
You also have the option to "voice over" (they call it "voice plus") whilst dubbing to another recording device, but this doesn't overwrite or alter the original recording. For full details of how to do this, see the user manual page 89. (If yours is not to hand, its freely downloadable from many sites, including Retrevo).
Hope this helps.
You can use either a microphone stand, or an adaptor to fit your tripod.
3answers
My external mic wont work! Please help.
If the mic is working on other camera's, what about the adaptor ? If there is a possiblity of checking the mic and the adaptor together on other equipment ? Use another mic with the same plug as the camera, ie. PC microphone (you can even test by using an earphone, the earphone can be used as mic) If it works then the XLR mic with adaptor is the problem. If ther other mic (used for testing) also did not work then the microphone jack (socket) in the camera is defective or the gain setting of the camera is set to minimum.
How do I connect an external microphone to my Toshiba Salellite Laptop computer?
Right click over speaker icon (next to your clock right bottom corner), click recording devices. Clic on your external mic, clic on properties, at bottom on the new window select "use this device (enable)"
My integrated microphone stopped working today when i was Skyping my mother. I have tried installing/upgrading the drivers but it isnt working. I havent damaged the laptop in any way. I really need help...
The best is to try with an external microphone to see if the fault is only on the microphone hardware. If so you can test and use with athe external for the time being and need not tamper the laptop mic .
But if you are able to open and change with your expertise thendo so.
however if the external mic does not log on then the audio section hardware is faulty.
External mic for Panasonic DVC80p
on page 49 of your owner's manual, the operation of the mic input switches is described.
I own a Panasonic PV-GS31 Mini DV Digital Camcorder, I am a Private Investigator and while recording the sound needs to be muted, how can I accomplish this?
Hi There, There is no external mic input on that model camera. The only way to do it is you will have to take the front panel off the unit and disconnect the flat mic/audio cable from the front panel. If you do this, tape up the connector so it won't short out the unit. If you had external mic in, you could put a dummy plug in and that would cut the sound from the internal microphone.
Thanks, me cicmo
I dont understand how to use an external mic. Use of external mic.
Your external mic needs to have a 1/8" plug. You will need to find the "Mic" input, this is generally found behind a removable or hinged plastic or rubber panel, and usually near the A/V plug connectors. When you plug in an external mic, the camera switches over to use it rather than the built-in mic. On this camcorder, you cannot set the recording level of the external mic. The camera sets the level automatically. So it is simply a plug-and-play, or plug-and-record solution.
Using an external mic allows you to reduce self-noise and handling noise. It is generally recommended for better videos. Different microphones are likely to interact in different ways with your camera and its automatic level-setting, so you should try out different microphones if you have more than one available to you.
Regarding the canon hv20 camcorder. When using an external canon MIC a) How do you know the mic is working and you are not picking up sound on the internal MIC b)On connecting the external MIC an icon...
If you put the camcorder in manual mode, there is a microphone sensor that will move when sound is picked up by the external microphone. In manual you can keep everything else automatic. The off for the mic means that the built in mic is turned off when an external mic is attached.
Microphone
the external mic must be unplugged for it to work and you need to reconfigure the internal mic if it doesn't work... there should be an option for this under start>settings>control panel> audio> microphone
Built-in microphone does seem to work
The only way to really tell if the buit in mic. is bad is to replace the mic or plug another one in the external mic. jack. Also use the input (red and white) RCA jacks and input a signal from a stereo or TV into it and record. If still no sound then its probably Bad capacitors in the sound processor Printed Circuit board. Sorry to be the bearer of bad news but mostly all of older camcorders suffer from this breakdown fault. Good luck
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
