SOURCE: rice cooker stopped working after one month's use
You probably should bring it to a service center. since youve mention a span of time not using your cooker, the thermal capacitor may be busted.
hope this helps.
SOURCE: I accidentally put the rice into the outer pot
The problem has been solved - the bottom cover of the rice cooker was unscrewed and pried off, and after removing the insulation, etc. the rice was removed.
SOURCE: need manual for Aroma rice cooker and steamer
CLICK HERE
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: ARC-838TC 20-Cup Rice Cooker: Lost the instructions on how to use the aroma arc ...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
You should have a button that says something like white rice and brown rice....the cook button is for steaming veggies...
Here
is a tip that will help you figure out about using a rice
cooker...
How
heatman101
