The most common cause of the symptoms you describe would be a shorted high voltage rectifier. You could also have either a shorted high voltage capacitor or shorted magnetron (uncommon).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
SOURCE: Microwave makes a loud noise while using.
After you turn it on, it's a loud noise like it's coming from the fan, but other then that it works wonderfully.
SOURCE: Microwave makes loud noise and does not heat. Smell of light burning
Chances are you have a bad magnetron.
If
it's within the magnetron portion of the warranty (usually 5-9 years)
but out of the original full warranty (usually 1 year), then your
manufacturer will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
If
you or someone you know decide to look into it, we have critical safety
information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
SOURCE: loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
SOURCE: GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
SOURCE: Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
