Try this:
If you forget your password
If you forget your password, you can clear it using the
following steps:
1. Press SETUP to display the Setup menu.
2. Input the 6-digit number "210499" and press
ENTER/OK. The password is cleared.
OR
1. Press DVD on the remote control.
2. Press SETUP.
The Setup menu appears.
3. Use v / V to select the desired option then press B
to move to the second level.
LOCK (Parental Control)
Rating
Blocks playback of rated DVDs based on their content.
Not all discs are rated.
1. Select "Rating" on the LOCK menu then press B.
2. To access the LOCK options, you must input the
password you have created. If you have not yet
entered password, you are prompted to do so.
Input a password and press ENTER/OK. Enter it
again and press ENTER/OK to verify. If you make a
mistake before pressing ENTER/OK, press CLEAR.
3. Select a rating from 1 to 8 using the v / V buttons.
Rating 1-8: Rating one (1) has the most restrictions
and rating eight (8) is the least restrictive.
Unlock: If you select unlock, parental control is not
active and the disc plays in full.
4. Press ENTER/OK to confirm your rating selection,
then press SETUP to exit the menu
Unlock
New
DG
AU
Move
Select
SOURCE: NEC NDT-40 DVD/VCR how to turn off "child lock"
on your remote down on the left hand side at the bottom of it its the second last button called c.lock its right above easy rpt press n hold till the little red key flashes and disapears off your unit !
Testimonial: "Exactly what I needed to know - many thanks"
NEC NDT-40 DVD/VCR has "child lock" engaged - key symbol showing in display window on unit. How do I turn this off so that the unit can be operated directly rather than only by the remote control? I do not have the remote control anymore!
