Computers & Internet Logo
s
sadik sule Posted on Sep 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Compaq Computer monitor Model PE1212 has a very dimme screen i have put Brightness to 100% but is still not working. what should i do?
Larry Ng
Level 3:
Top Expert:
  • Compaq Master 14,592 Answers
  • Posted on Feb 07, 2022
Larry Ng
Compaq Master
Level 3:
Top Expert:
Answers
14592
Questions
0
Helped
3278307
Points
66578
All old monitors are dead now, yours only dim, 15" LCD relic
Compaq Monitor PE1212 Used A 1024 x 768 LCD 15" year 2002 made
all had, CCFL back lamp tubes.
all are bad for::
  1. Dim
  2. dead
  3. 1/2 tubes bad, 1/2 screens
  4. blinks or strobes
  5. yellow tinged white screens.
  6. works only hot or cold. or intermttant.
what;s to like about CCFL, zero
buy 2010 and newer monitor with LED back lamps.
6helpful
2answers
I have a compaq paserio notebook and when I boot up the computer, either I get a blank screen or I get a very faded image that I can't hardly see so I can't log on. Most of the time I just get a blank...
Have you checked the brightness options for the screen using the HP function keys? Fn +F7 or Fn+F8 should adjust the brightness of the screen for that C306 model laptop. If adjusting the brightness has no response then try the next steps.
What happens if you turn the computer off, plug it into an external monitor or projector, and then turn the computer back on? If the video displays correctly on a computer monitor or projector, but it stays dim on the LCD screen of the laptop, then the laptop LCD Screen Back-light or inverter is probably going out. You'll need to contact HP for a replacement part or take the laptop to a certified repair center.
2answers
8helpful
3answers
My acer AC713 monitor's brightness value gets reduced to zero.
Dear sir,
This is common problem arises mainly due to moisture,especially in rainy season,Monitor front panel control buttons remain pressed,due to deposition of ferric oxide and moisture in between monitor botton panel and circuit board.So you can dry this moisture by hanging a bulb of 60 watt nearer a monitor about 4-5 hrs,(too near may damage the internal heat sensitive parts.).It solves your problem.....and also you may clean the inner monitor button contacting circuit by means of PCB cleaner to wipe out ferric oxide deposition.
if you had any query regarding this issue leave a feedback we glad to assist you.
good luck.
1helpful
Speakers compaq tft5015
There are no speakers in my Compaq TFT5015 model No PE1212
Are there really any in yours??
COMPAQ 7500 monitor, MenuBar/Brightness Bar, Keys not working
replace Menu buttons (Microswitches) and check 5v path
check dry points.
1helpful
2answers
Problem with brightness of monitors SyncMaster 710n
HelIo! right after computer inclusions on the monitor screen have a tablet with the message which disturbs to work. The message: brightness of the monitor of 100 %! A problem: how to clean from the screen this tablet so she prevents to read the information. I have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another? have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another?Thanks and sorry about my bad english. Afzal.
Brightness control+blurrness of images+
no can do. you monitor is dead in the water.
lost of focus, and intensty. all point to one thing.
by the way, do you have the correct video driver installed???
How to maximize color of monitor?
The monitor and laptop are not compatible or the cable is not properly connected.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
