Question edited for clarity.
Question moved form Car Audio to Pride Jazzy Select 6.
9 Flashes The park brakes have a bad connection. Check the left and right motor connections and wiring. Check to make sure that the power chair is not in freewheel mode.
www.pridemobility.com/...manuals/...jazzy/.../au_jazzy_1... Pride MobilityJAZZY 1122. How a Power Chair Should ... NOTE: This owner's manual is compiled from the latest specifications and product information available at the time of .
Low batteries Outlaw. If you have charged the batteries and after only a little while you get the blinking red light -----Time for New batteries. Hope this helps you
Bob on each brake at the motor there is a micro switch that the controller gets connection info as to wether or not the chair is in freewheel. I have seen these switches break and therefore the controller thinks the chair is in freewheel. you could also have a bad brake solenoid that is not activating the brake when you try to move. I think the micro might be the problem because you say it flashes 9 times as soon as you turn it on. You can get just the brake assembly from Pride instead of buying the whole motor/gearbox assembly. You didn't say if you bought the chair or Medicare. If Medicare did then they will pay for most of the repair you can contact your provider or a repair service Repair Xpress @1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
