SOURCE: 2005 Tucson
camshaft sprocket bolt 58-72 ft. lbs. crankshaft pulley bolts 108-132 ft. lbs. crankshaft pulley center bolt 80-94 ft. lbs. cylinder head bolts cold engine 65-72 ft. lbs. warm engine 73-80 ft. lbs. cylinder head rear cover bolts 69-86 in. lbs. flywheel/Driveplate bolts 94-101 ft. lbs. intake/Exhaust manifold nuts/Bolts 11-14 ft. lbs. jet valves 13-16 ft. lbs. main bearing cap bolts 36-39 ft. lbs. oil pan bolts 51-69 in. lbs. oil pan nuts 43-60 in. lbs. oil pan drain plug 33 ft. lbs. oil pump cover bolts 72-84 in. lbs. oil pump relief valve plug 29-36 ft. lbs. oil pump sprocket nut 25-28 ft. lbs. Rear oil seal retainer bolts 84-108 in. lbs. rocker arm shaft bolts 14-15 ft. lbs. rod bearing cap nuts 23-25 ft. lbs. silent shaft sprocket nut 22-28 ft. lbs. spark plugs 15-21 ft. lbs. thermostat housing-to-Engine bolts 86-114 in. lbs. timing belt tensioner bolt 32-40 ft. lbs. valve cover bolts 43-61 in. lbs. water pump-to-Engine bolts alternator brace bolt 14-20 ft. lbs. all others 9-11 ft. lbs. water pump pulley bolts 72-84 in. lbs.
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
SOURCE: Need Cylinder head bolt torque specs and sequence
Tighten the cylinder head bolts to 50 N·m (37 lb ft) in sequence.
SOURCE: i need the engine torque specs for 99 chevy malibu
99 chevy malibu v6 3.1 engine, head bolt torque is-- 98 through 2001 is step1- 37 foot lbs, step 2- rotate an additional 90 degrees (1/4 turn). the rocker arm bolts are 168-in. lbs.
Fig. 7: Location of the cylinder head retaining bolt holes
Fig. 13: Cylinder head bolt torque sequence for 2.2L engines
Tighten bolts in sequence, tighten the long bolts to 46 ft. lbs.
(63 Nm) plue 90 degrees. Tighten the short bolts to 43 ft. lbs. (58 Nm)
plue 90 degrees.
Hope helps.
