Linksys By Cisco E2500 DualBand WirelessN Router Logo
B
Betsy Bartow Posted on Sep 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to change the password on my Linksys e2500
I need to change the password and settings
Prashant M
Level 3:
  • Linksys Master 2,278 Answers
  • Posted on Jan 31, 2019
Prashant M
Linksys Master
Level 3:
Answers
2278
Questions
Helped
978170
Points
6246
In order to change the settings of the Linksys router, you will need to login to Linksys router setup page.
If you have installed Linksys/Cisco connect software on your main computer then you can change settings using that installation program.
here is link which may help you with Linksys E2500 router.
https://fixhomenetwork.com/blog/linksys-e2500-router-setup/
3answers
I want change my liksys roter password E900.can any help me please My no is 0506327008
Linksys router is the best network service provider between another router service provider, there are features provide high-speed internet, multiple connectivities, easy for installation and etc.
To troubleshoot Internet connectivity issues:
First of turn off your router and connect modem directly with your computer.
Login your router by following login manual steps.
Click the Smart Wizard Test button to access the NETGEAR online test page.
Under Router Status, and check your router has a valid IP address. For more information, see your router user manual setting.
We have very expert technicians who always ready for the solve technical problems, the customer connect with us by dialing a toll-free number. Our service is available 24*7 for the customer who faced some technical issue with router contact Linksys Router Phone Number by dialing toll-free number for the other service visit service number website and get solutions.
https://servicenumber.org/linksys.html
Jul 10, 2016 • Cell Phones
I have a Linksys E2500 Router. I do not remember having a password, but apparently I do. How do I find it?
You actually may not have set up a password on the router. It comes from the factory with a default. The default username is left blank and the default password is "admin". If that doesn't work, then there is a different password on the unit. You can clear the password by doing a factory reset on the device, but then you will need to use the defaults to go back in a set up the device all over again. The external reset method is to press and hold the RESET button on the bottom or the back of the unit (it may be recessed into a small hole that you will need to use a paperclip on) for a minimum of ten seconds.
Forgot my password and need guest password
Unless you set one up, you will need to reset as I previously answered.
You might want to try the admin password: leave the user name blank, and enter the password "admin"
2answers
I have a linksys E2500 and I need the password
You could try to connect to your router with a CAT5e network cable. Then open your browser and open the webpage http://192.168.1.1
When prompted for your username and password, try password 'admin' (without quote marks) and leave username empty.
If that doesn't work, reset your router and configure all the options over again (make sure you have all required information for the settings). For more information, look at this knowledge base article: kb.linksys.com/Linksys/GetArticle.aspx?docid=6af0fc7147664d2eaef47a2189a1ffce_E2500_FAQs.xml
I cannot remember my password for my wireless
admin is the default out of the box if you changed it you have to reset router use admin then change it after you get back on line
go to linksys.com support type in your model # look thru FAQ's or download manual
Forgot linksys e2500 wireless password
You could do a factory reset. This way, the unit will revert to the default username and password. You'll need to reconfigure all the settings though.
2answers
Forgot guest pw on cisco e2500
If a password was set by user, no one else will know it if you forget it.
If the password needs to be reset to factory, so you can log in with the "default" password AND RE-SETUP EVERYTHING, then you'll need to reset the Linksys E2500 to factory defaults. You can usually do that via a special button or sequence of actions.
The E2500 manual will have specific directions for performing a factory default reset. You can download the manual for the E2500 from http://support.linksys.com/en-us/support/routers/E2500
My Linksys E2500 router won't fully power up. The lights are dimly lit.
Start to change:
1-Charger / Cable then;
2-Test; no luck?
3-Device is dead
Have a linksys router trying to connect need default password or cisco password
By default, the router has a SSID ID of 'linksys', with *NO* security, and *NO* password. Configure the router to enable security, and to set the SSID and to set a password.
I WANT TO CHANGE MY PASS WORD ON MY LINKSYS E2500
access the ipadd of your linksys then thats the time you can change your password. if you dont know the password then its time you reset your router and reconfigure it again.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
