I have a Belling DB4 90Ei induction range Cooker. I have noticed that when I use the induction hob that a buzzing noise comes from it . Should this happen
An E6 error code on a Belling induction hob typically indicates an issue with the power supply or the circuit board that controls the back two rings. Here are a few steps you can take to troubleshoot the issue:
Reset the hob: Try turning off the power to the hob for a few minutes and then turning it back on. This can sometimes reset the circuit board and clear the error code.
Check the power supply: Make sure the hob is receiving a stable and adequate power supply. Check the circuit breaker or fuse for the hob to ensure it is not tripped or blown.
Check the wiring: Inspect the wiring and connections for the back two rings to ensure they are not loose or damaged. Tighten any loose connections or replace any damaged wiring.
Contact a professional: If the issue persists, it may be a problem with the circuit board or control module. In this case, it's best to contact a professional technician or the manufacturer for assistance with repairs or replacement parts.
I hope this helps you resolve the issue with your Belling induction
Unfortunately, Induction hobs on domestic cookers have always been a problem. A single, one ring catering hob is $1,200 and is expected to last 2 years in an industrial environment.
There are two videos here, but I reckon you will need a service call.
Induction stovetops wont heat until a metal pot is put on top of the element. They work through electromagnetism. These tops wont work with glass or aluminium pots. They have to be steel.
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Do you mean the pans or the cooker is not flat/level
