The symptoms you're describing could indicate several possible issues with your Ice-O-Matic ice maker. It's possible that the problem could be related to the timer or relay, but there are other components that could also be causing the issue.
Here are a few potential causes for the problems you're experiencing:
Thermostat: If the thermostat is malfunctioning, it may be causing the ice maker to freeze too long, preventing it from entering the harvest cycle properly.
Water inlet valve: A faulty water inlet valve can cause the purge valve to constantly dump water and can also prevent the water reservoir from filling up properly.
Control board: If the control board is faulty, it may not be properly controlling the ice maker's functions, including the harvest cycle.
Harvest assist: If the harvest assist mechanism is not functioning properly, it may not be able to break the ice free from the evaporator plate during the harvest cycle.
Given the complexity of diagnosing and repairing an ice maker, it's best to consult with a qualified technician to diagnose and fix the issue. You can search for local repair services in your area or contact the manufacturer for a referral.
go to the freeze timer which has off and on dip switches. take some freeze time out by moving the first switch to off this will shorten freeze time. Also check the harvest assist solenoid and plunger when it go's into harvest. make sure the machine is cleaned and check the cube plate to make sure that none of the plates are not loose this will cause ice to freeze between the loose spots and will not let ice come off the plate.
There are three easy things to look for. First in the center of the ice grid there is a plunger rod that pushes the ice out. Need to make sure that is all the way in on start up. Second the ice curtain has a tab on the top right that has to be behind a metal switch tab that sticks through the side on the unit. Third on some units right in front of the water trough is a thin metal rod, that is actually the bin thermostat. If there is any ice laying on top of that rod it will shut the unit off at a full bin.
Yes if it has a bypass leak it will pump water out at same time as pumping over evap. try pinching off the dump valve hose just after starting a freeze cycle and see if it makes a full sheet
Check that Ice cubes are freeezing completely before dumping into tray. Check that spray nozzle isn't inadverdantly clogged and spraying water everywhere. Check that water inlet solenoid is actually closing and not leaking water into bin. Check thermostat for the bin not working properly, frozen over or something.
i think it might be located on the panel at bottom were warm air blows out an sucks in cool air...remove the screws...or on back of machine...hope this helps.....good luck/
i fix that p.m me
