Look at the master switch connector terminal #6 is a yellow wire jumper battery positive there Terminal #9 is a black wire this is the ground wire jumper it to a good ground.
There's a 30 fuse or fuse link in the under hood fuse block check it,
locate the power window relay on the left end of the dash and swap it with one having the same number, if there's not another relay use a small jumper wire to jumper terminals #4 & #5 together to bypass the relay.
I hope this helps. Take Care.
Don't worry about it until you've checked the Related fuse2 or possibly a relay- your owners manual will tell you where the fuse is or a google search will if you don't have access to a manual- checking the fuse(s) and relay(if it has one) is the best place to start. Check it out and let us know what's up so we can help- best of Luck friend!
There is no relay for the windows, if all windows aren't working, check the fuse (#2). It could also be a faulty windows on/off switch on the drivers side.
The fuse must be in the main fuse box. The position of the fuses is normally marked on the inside of the fuse box cover and also in the owner's handbook. If you don't come right with these, work your way through the fuses looking for a blown one. To ease your search the window fuse should be between 20 to 30 amps.
it usually runs on the same fuse as the radio & interior light which is the accessories fuse, if these two things still work you may have another problem with the wiring,you might need to pull the lighter out & check the wiring.....hope this helps.....cheers
