Replace the magenta (Red ) image unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: c451 Bizhub Konica Minolta printer
press utility. press metercount. press metercount details. press stop 0 0 stop 0 1 to access service mode in service mode look for admin initialialation function
SOURCE: error c3921
C3921: Fusing sensor wire breaks detection (Center of the heating roller)...
• At the warm-up stage, the heating roller
thermistor/3 voltage does not decrease by
predetermined steps (temperature rise)
within a predetermined time.
Check the fusing unit for correct installation
(whether it is secured in position).
Check the open/close operation of the
upper right door.
Check the fusing unit, IHPU, PRCB and
REDB for proper connection and correct or
change as necessary.
If that check still give you error code 3921
Change fusing unit
SOURCE: how to solve error code c-2553
The toner abnormality you have to clean toner hopar and clean senser and again OFF and ON
