SOURCE: install reed valves hitachi air compressor need pics
I believe in your model of air compressor, when you take apart the head portion to your compressor you should have four reed valves. When you have it apart, there should be two "grooves" on the bottom "plate" and two "grooves" on the top plate (where the reed valves go). the bottom part is easy (as you should already know) to set in the reed valves, but as i have also found out, as you probably have, that its a little more difficult to line up the other reed valves to thier "grooves" on the upper "plate". What you do to make sure that they stay in place is dab a little oil or grease on the reeds and place them in the upper "plate grooves" and carefully set the upper plate back in place where it goes on the compressor. It will hold them in place long enough to install it on the compressor and the small amount of grease that was there will quickly be burned up with no effect to the opperation to the machine.
Sorry, long winded explanation. hope this helps and if it didnt get to you soon enough i hope it helps out in the future. :-D
Hi Walter Brittingham, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
