Watches Logo
Timmy tran Posted on Sep 12, 2016
Fossil fs4141 battery size - Fossil Watches
Battery for fossil blu ch-2495
Fossil battery replacement sizes are usually a 2430 (CR2430), 371 (SR920SW), or 377 (SR626SW).
https://www.fossil.com/en-us/******/how-to-change-a-watch-battery
Which battery does a Fossil Big Tic JR-9779 (Chinese Dragon)watch take
Fossil Watch Battery Replacement - Ultimate Size Guide -
batterymole.com https://batterymole.com > fossil-watch-battery-replace...
Aug 21, 2022 - The CR2430 battery is a 3v lithium battery, see the shape below. This example is made by Renata, but you can also get the produced by Duracell, ...
I am trying to find out what size battery is used in the fossil fs4775 watch...
Take it to a watch specialist who will open the case and be able to measure the battery compartments dimensions to specify the required battery and replace it for you.
Battary size for fossil blue watch bq8775
Thanks for contacting Fossil.
The only way to know the battery size is to pull out the old one. It might also be in your manual. It might be on the outside of the watch.
If battery is missing, then you will have to measure the cavity and match it against a battery chart.
Best wishes.
1helpful
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
