I hold a lappie (Zenith admirale SW8 EAA-89) I found a Wi-fi on/off indication and a key printed the symbol of wi-fi. But I don't know/unable to s/w on the wi-fi such that i can access my wi-fi router
Turning Wi-Fi on and connecting to a Wi-Fi network 1 Touch > Apps tab > Settings > Wi-Fi from the WIRELESS & NETWORKS 2 Set Wi-Fi to ON to turn it on and start scanning for available Wi-Fi networks. Tap Wi-Fi menu again to see a list of active and in-range Wi-Fi networks. • Secured networks are indicated by a lock icon. 4 Touch a network to connect to it. • If the network is open, you are asked to confirm that you want to connect to that network by touching Connect. • If the network is secured, you are prompted to enter a password or other credentials. (Ask your network administrator for details)
On the top of the tablet is the Wi-Fi & Low Power Button. Make sure that it is "slid" to the left.
1. Tap Wi-Fi settings to select and connect to a local wireless network. The device automatically scans and lists local Wi-Fi Networks found. A indicates secure networks that require login passwords to connect. 2. Tap the desired network to which you want to connect. If your Wi-Fi broadcast is set as hidden, it won't be found by the auto scan. Tap Add Network -> enter the network name and key, -> tap Save. 3. If the network is secure, tap in the password entry field to enter the Network Password. 4. Tap Connect. 5. Tap < to return to previous screens. The Wi-Fi symbol on the top of screens indicates the Wi-Fi is connected, otherwise no icon is displayed
If you did all of the above, get a hold of Pandigital
Hi,Usally there is a switch for the Wi/fi on the side panel, its a slide switch , if not then on one of the Function keys i.e from F1- to F12 there will be a wi-fi symbol, then press both the keys together i.e the FN + the wifi key, if ur r not able to still switch on the wi-fi check if its disabled in the system, or take a picture of the keyboard where all the keys are visible and send it to me,
Let me know.
Hi Fred! I have checked the specification of your laptop here and found that your laptop is Wi-Fi capable and wi-fi drivers are available and can be downloaded and installed here. (if required) Most Gateway notebooks have a designated multi-function button or function key to turn your wireless on and off. There should be a tiny slide switch or button with a small antenna
symbol. There should also be a light with the same symbol to show when
it is on and from the keyboard Press Fn+F2 to enable wireless.
Let me know if any further clarification/ assistance is required.
Good Luck! Dont forget to appreciate the solution if I could have been of any help! CreativeTECH
If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
Verify that the Wi-Fi network settings are correct:
Tap Settings > Wi-Fi.
Locate the Wi-Fi network you are currently using and tap
You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information
If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
