It frozen on a bot screen and won't even turn off or anything else.
I have a ZTE cell phone a real big one that I have to stick a pin in that comes with the phone I stuck that in the back of my Le Pan tablet to reset it and it worked I pressed it twice it reset the tablet. Thanks Thanks Eduardo Cobos.
Hello, All you need to do is find a toothpick or needle and there is a little hole in the back that says "reset" it will reboot the tablet and no data will be lost. Hope this helps!
Testimonial: "Sorry I've tried this several times and nothing has changed. Any other suggestions?"
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
Press the "n" button to display the quick nav bar.
In the quick nav bar, tap the Settings icon.
In the Device Settings section, tap Device Info.
Tap Erase & Deregister Device.
Stop. Think. Think again.
If you really, really want to do this, go to Step 7. If not, tap the Back button.
Tap the Erase & Deregister Device button.
I have tried this several times and nothing has changed
It works! I'm so thankful.
Same here
