XM radio works just fine but no FM or AM Radio?
There's always the possibility that when hi-fi or electronic systems are moved, that they will get knocked about it. This might loosen solder joints or crack pc boards. A visual examination of the inside of the unit might reveal one of these.
Having seen a picture of the back of the unit on the net. It looks like there are 8 screws located around the outer edges of the unit. 3 along the top, seen joining the black to silver plate. Two at either side, one near the power cable. And lastly 3 at the bottom edge. Ignore the others in the main part of the back panel. The quality of the image I have is poor so I can't see what type of screws they are. They might be tamper proof, not the slotted type. So if they are you will have to search for a tamper proof screwdriver on Amazon.
SOURCE: No sound from system when watching TV
I figured out a solution...I tried the red & white audio in/out, and it did not work. The only thing that will work is using an optical cable...$25 at Radio Shack...worked like a charm!
SOURCE: No TV audio coming from Sony DAV-HDX500.
If you are trying to make your TV audio come out your Sony system, you didn't say what the input to your TV was from (ex;Cable TV,Sat TV).
Sometimes it is easier to take the external (cable or Sat) out puts and feed the video into the TV but the red white into the AMP (TV input)then select TV on your AMP to hear TV.
Also some tv's need to make a speaker choice! go to Set up and change the speaker set up for the TV, you may have to tell the TV no speakers to create out put to Amp from the REd White TV out put.
SOURCE: Need a Region unlock code for Sony DAV-HDX500
have you checked your settings menues yet regions should be selectable
for that new of a player
i recomend buring your dvds with out a region code or atleast a region code that conforms to your standard player ! search downloads.com for an aplication to do this
SOURCE: where can i get a fm antenna for sony brava dav-hdx500
Get some single strand wire 18 or 20 gage about 5 feet. Strip about 3/8 of an inch of insulation from one end and put that end into the plug. Thats all you need.
SOURCE: No color when playing DVD's on Sony DAV-HDX500.
What's different? The video connection type, maybe? If you're using Component cables (Red, Green, Blue) you might want to check their integrity.
Now I need to figure out how to open the receiver/DVD unit!
