SOURCE: samsung refrigerator
There is a screw down foot in front of each forward wheel under the fridge. You can access this by looking under the front corners.
SOURCE: I have NEW sumsung ref. 25.5 french door with freezer at bottom
Had the same problem, your ice maker is a known defect, insist they replace it. Don't expect heavy ice output -- our biggest complaint.
SOURCE: My Samsung French Door RF266ABPN has a warm
I have read that if you unplug the unit and plug it back in again, it will "reset" it. I would wait 15 or so minutes before replugging just to be sure. Of course, this solution doesn't preclude the problem from happening again - sounds like a manufacturing defect to me.
SOURCE: I'm getting frost in freezer of my Samsung french
i would check the magnetic seal around the door to make sure it is not letting air in ...this is the cause of the over freezing.
You should be able to download this directly from Samsung's website, www.samsung.com. Just have your model number and serial number if needed.
