Looked everywhere and can buy the battery but, not the charger ...Help ??
SOURCE: battery and charger
check out www.ebay.com and type durabrand dur7 , they have the charger available there , hope this helps AJ
SOURCE: Battery charger for a JVC GR AX230 camcorder
All I wanted was to buy a charger, so I don't need your help. I found one. thanks.
SOURCE: need the battery
Have you tried Batteries Plus near you or go online to www.batteriesplus.com
they list both the batteries and the chargers for this model of camcorder
SOURCE: My dremel 10.8 lithium ion
The battery has been overcharged.
You will need a new one.
Thanks!!!!
SOURCE: hi I have a dremel
Same problem with my 780 and have had no luck with a genuine charger and Dremel have discontinued it. I resorted to using a 10volt charger bought online and connected the the two wires to the battery terminal. + to Plus and - to minus. A bit dodgy I know but you can't get a wallop out of 10 volts, just keep and eye on it in case you start a fire! (very unlikely ). Feel the battery every now and then and when it gets a little warm, turn the charger off and make good use of the Dremel. I know this is not perfect solution, but the only alternative is give up on a perfectly good tool or buy the whole kit second hand (drill box and pieces etc).
