Your amp has two inputs - Passive and Active. Do you get the same results plugging into either one? If only one works, then the other needs reconnection or replacement.
What kind of problem are you having with this, I assume impedance matching. 2 speakers in parallel cut impedance in half. ex. 2 x 8ohm in parallel equal 4 ohm. IF the same speakers are in series, they double impedance, ex. 2 x 8ohm in series equal 16 ohm. Now matching 2sp and 2 sp, both pairs SHOULD be wired the same and the removal of 2 (dep on config) usually would be treated as 1 ?ohm circuit that equal the other ?ohm circuit. AFTER the removal of 1 leg, the impedance could double or half, depending on configuration.
Go to www.peavey.com/asstes/literature/specs/005584220_3.pdf. Apparently the 410 TVX can be used in 4ohm or ohm configurations just don't drop below 4 ohms and make sure your amp has the minimum required impedence. Hope this helps.
Start with a clean setting - zero cut and zero gain on the Eq.
Play a song close to the amp, and then move away, playing the same notes. Do you still get the distortion?
Change lower the input gain and repeat the test.
Lower the output gain and repeat.
Are any outboard distortion pedals in the mix, such as overdrive?
Eliminate them. Run straight through from your axe to the amp.
Check for any distortion settings. Set everything including reverb to zero. When the distortion disappears, this is your base setting.
Change only ONE parameter at a time. When the distortion comes back, you have found your problem.+
There will be some overlap in bass response that you may need to tune out to tone down the boomy bits. You could tune this out with a 31 band EQ Another approach is to use a crossover or low pass filter to the subs to get some control over your bass frequencies. Another thought, if you're using the rig for stage work, how does it sound out the front. It may be standing waves created by the bass bins, moving them to different monitoring positions may also help.
I am more than happy to answer
any other questions you may have about it, just give me a hoy :) If you
are still unsure, or have problems, then before you give a rating for this advice, please
get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you
as sound, a FixYa rating is a great reward for my efforts to help
you. Cheers.
