Question about Razor E100 Electric Scooter
I have 2 razor e 150 scooters and neither one will work ! the batteries have been charged and every time they turn the control on the handle bar it just clicks and no go
I have replaced the control module and just a click ! I know the motor works cause I bypassed the control module and the motor fired up ! whats up please
    Top Expert:
  • Razor Master
  • 85,206 Answers
Then the batteries are worn out, simple as that. Just because the batteries are charged doesn't mean they accepted the charge, a common mistake. Go to ebay and you can find a replacement battery most likely/
Posted on Sep 07, 2016
SOURCE:
COULD THE GAS PEDAL CABLE CAUSE THIS CODED PO507 to be high
Extracted from Engine-Codes.com
Code P0507
Possible causes
- Dirty throttle body
- Electric throttle control actuator misadjusted or damaged
- Faulty Electric throttle control actuator
- Intake air leak
- Poor electrical connection to the Intake Air Control (IAC) valve
help.jpg What does this mean?
Tech notes
If there are no intake leaks, clean throttle body, adjust engine idle and erase engine code. If the code comes back you may have to replaced the Electric Throttle Control Actuator (Motor) to repair the problem.
There is a factory service bulletin for the following Chevrolet models:
2006-2008 Chevrolet Trail Blazer
2007-2008 Chevrolet Avalanche
2007-2008 Chevrolet Express
2007-2008 Chevrolet Silverado
2007-2008 Chevrolet Suburban
2007-2008 Chevrolet Tahoe
Chevrolet Factory Service Bulletin OBDII Code P0507
When is the code detected?
Thi P0507 code sets when the Powertrain Control Module (PCM) detects an engine speed outside of the Idle Air Control (IAC) valve range of control.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Engine hard to start
- Rough or erratic idle speed
P0507 Chevrolet Description
The Idle Air Control (IAC) valve is a Powertrain Control Module (PCM) controlled stepper motor located on the throttle body. The stepper motor drives a valve pintle which protrudes into a passage that bypasses the throttle plates. The PCM commands the IAC valve pintle to extend to decrease the idle speed. The bypass air flow is reduced and the idle speed decreases as the pintle approaches its seat. The PCM retracts the IAC valve pintle away from its seat to increase the idle speed. The retracting of the IAC valve pintle allows more air to bypass the throttle plates. One of the PCMs uses for the IAC system is to maintain a desired idle speed. This DTC sets when the PCM detects an engine speed outside of the IAC\'s range of control.
Read more: http://engine-codes.com/p0507_chevrolet.html#ixzz3ObdI2chF
Jan 11, 2015 | 2001 Chevrolet Blazer
Jacuzzi whirlpool won't start.
Fred
The problem you are experiencing is most likely to be caused by the control box.
If you plug the motor in and it is working, I would replace the control box first.
That is where you would start first. The button on the top of the tub does not go bad very often is this situation.
Rod
US Parts Center
Mar 16, 2014 | Jacuzzi SIG7242WCL2CJW Signa 6 Plus...
Gw511
Your lid will not lock will this Error code.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
(Refer to Section 2.7.2).
37
Jun 07, 2013 | Fisher and Paykel GWL11 Top Load Washer
1992 chevy C1500: Heat works on low speed, no medium, and high only works intermittantly.
On any other vehicle it sounds like the blower fan switch.
The fan switch provides power or ground to the resistor and there would be a high speed blower relay to bypass the resistor.
But in your case the fan switch is part of the controller.
I don't have a diagram for a 92 but the 94 model shows relays for low medium and high speeds. Each relay gets power from a fuseable link. The high relay gets power thru the low relay if the low relay is not engaged.
If you have the model with 3 relays you may need to check them.
Feb 01, 2013 | 1992 Chevrolet C1500
My machine stopped and made a constant beeping while the 3rd, 5th, 7th & 8th lights across the top remained on. What does this mean????
It sounds like this is a Fisher and Paykel-made top load washing machine and you are referring to the Wash Progress LEDs. The flashing of the 3rd, 5th, 7th and 8th LEDs from left to right indicates fault code 43 and it means the Motor Controller Module has detected that the out of balance switch is permanently tripped. The out of balance switch lever may have been stuck in the open position or the harness connecting it and the Motor Controller Module is disconnected.
Move the basket assembly as far as it can go towards the right hand rear corner of the cabinet several times to possibly lodge the lever back into close position. Raise the top cover then locate the out of balance switch at the right hand corner of the cabinet then make sure the lever is hanging freely. Disconnect the out of balance switch wire harness, if the lever is properly hanging but the same LEDs are still flashing (Fault Code 43), then join the terminals together to bypass the switch.
Reconnect power then start the machine. Replace the out of balance (OOB) switch if the machine works fine with the switch bypassed. If not, check the continuity of the OOB switch wire harness and make sure it is snugly connected to the Motor Controller Module. The problem is in the Motor Controller Module if the wire harness is intact and snugly connected but the machine still doesn't work even with the OOB swicth bypassed. Replace the Motor Controller Module if that is the case.
Mar 22, 2011 | Washing Machines
Duet dryer doesn't run. control panel lights up. push on button and all you hear is a click. what do i do?
No dryer function works when the motor cannot run and the common issue is a blown thermal fuse located on the blower housing and wired in series with the motor. There will be no power to the motor when the thermal fuse blows and the motor cannot therefore run. Bypass the thermal fuse and if the motor runs, the thermal use is indeed blown and needs to be replaced. Do not use the dryer with the thermal fuse blown due to fire hazards.
Disconnect power then open the dryer door and remove the lint filter. Remove the screws from the toe panel and remove the panel. Remove the screws securing the lint duct and remove the duct.
The thermal fuse can now be bypassed or replaced if necessary.
Bypass the thermal fuse by disconnecting the wires and taping them together or jumping a wire between them. Once done, plug the dryer in then start it. The thermal fuse is indeed blown and needs to be replaced if the dryer runs. The thermal fuse is part number 3390719. Reassemble the dryer in reverse order of the disassembly steps.
Oct 10, 2010 | Whirlpool Dryers
1985 gmc vandura 2500 will not fire when trying
Sounds like you may have problems with the ignition switch. The starter is turning over? But the motor doesn't fire, until you turn the key off?
Mar 16, 2010 | 1985 GMC C2500
Bryant furnance clicking, won't fire
try checking the pressure sensing switch,it has a tube that should run somewhere close to the inducer fan.sometimes this hose fills with liquids,and makes the units act funny.I don't know if you have a condensing unit or what.the furnace wont try to light if it cant tell the inducer motor is running.any induced draft unit will work this way.you can also do a temp. bypass of the pressure switch to make sure the contacts on it are closing just be sure your inducer fan is running,and you cant leave it like that its just a test.that is a safety feature you really need.
Mar 11, 2009 | Heating & Cooling
Razor E100 Electric Scooter Logo
143 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
ROB
Are you a Razor Toy Expert? Answer questions, earn points and help others
