Question about Korg PA800 61-Key Professional Arranger Keyboard with Speakers
How can I reset to factory sitting ? It just does not load all the way the program.
It does not load everything to start ,it gets stuck half way.
    Top Expert:
  • 84,625 Answers
You need to make sure the device memory is not full, that is the most likely problem here.
Posted on Sep 07, 2016
SOURCE:
How do I reset a Dell Laptop Inspiron M731R
If at all possible, a whole new fresh start means, "Reformat".
Backup if at all possible and then go ahead & follow the steps to Reformat.
Note:.... Reformat will erase everything and you will have a laptop, like when you first bought it.
Good Luck
Nov 14, 2014 | Dell Inspiron M731R Laptop Computer
Factory reset hp Compaq 6910p
This is how you put it back to Factory Settings...
1) Press and Hold the F11 key during boot.
If you are unable to get into Windows to start the recovery then you start the process when you first switch on the PC.
As soon as you turn on your PC, tap the F11 key on the keyboard until you get the "Windows is loading files..." message. When Recovery Manager has loaded click advanced options. Choose system recovery.
If you wish to try and backup any data then choose backup your files first and follow the on screen instructions. To run the recovery without backing up your data choose to recover without back up.
The recovery will launch and restore your system back to it's factory default state.
This is how you put it back to Factory Settings from desktop...
1) You can start the recovery from within Windows as follows:
Click Start
Click All Programs
Click Recovery Manager
Click Recovery Manager again
Click next when the Recovery Manager program loads. You will be prompted with several questions before the recovery starts.
"Would you like to perform a program recovery?" - choose no
"Would you like to perform a driver recovery?" - choose no
"Would you like to launch Microsoft System Restore?" - choose no
"Would you like to recover your computer to its original factory condition?" - choose yes
The computer will now restart and launch the recovery program.
NOTE: Some computers are F10.
OR
1) Turn on the computer
2) Start tapping/pressing F12 for Boot Menu
3) Insert HP Recovery Disc
4) Select DVD/CD-ROM and press enter
5) Press any key to start the installation
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703#RestoreWithoutWindows
I’m happy to help further over the phone at https://www.6ya.com/expert/jonathan_828b54f422cbefdd
Oct 17, 2014 | HP Computers & Internet
My craig tablet wont start up
Try factory reset. Press the hidden reset button while powering the unit. This should clear out everything that caused the hangup.
Apr 13, 2014 | Tablets & eReaders
Hi, we have a Siemens IQ300 Condenser Tumble Dryer which we have recently inherited. Unfortunately it worked for a wek before just stopping. The lights are on and everything looks normal but when you
Check to see if it is properly grounded and that the incoming voltage is correct (120V or 240V) for the wiring config you have.on the dryer as it sits. Also try unplugging and wait a minute or so before plugging back in. This will sometimes reset dryer electrical components to factory settings.
Dec 07, 2012 | Dryers
My Zanussi Electrolux Essential 1200 washing machine ZWF12070W1
Most times unplugging a washer for 5 min or so will reset to factory. Some units just a quick unplug works too. But I'm not totally familiar with yours.
If it's going to be hard to unplug just turn off the breaker to it.
Hope this helps
Feb 27, 2018 | Zanussi ZWF12070 Front Load Washer
I have a dvdvr375 that needs factory reset. How?
Try unplug,replug the unit back an hour later,should have everythings,reset to Factory setting.If no,electronic component's parts burn in ur device.
Jul 29, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
The washer got stuck half way before program is finished
your drain pump isnt working or there is a blockage in the sump, drain hose or plumbing
Mar 30, 2010 | Zanussi ZWF1440 Front Load Washer
Prints half the label.
Try reloading the forms from the AS400 by restarting the program. That should get it to work.
Jul 03, 2008 | Zebra 105SL Thermal Label Printer
Acer 5610z will not start
I had the same problem with my neices Acer 5100...Went into safe mode, it loaded the drivers and sat that for what seemed forever...almost like it was hung up....I had a few things to do...and a couple hours later, it finally booted into safe mode.
I was able to save her files, but ultimatly ended up wiping everything out because of the corrupt files.
On another Acer, the same hang up "unable to boot into safe mode" even after a long period of time, and that Acer was a total loss..had to format...
I presume nothing was saved to a CD? i.e. her gsce files?
Doing a factory restore/reset will loose everything.
Try to boot into safe mode and allow it to boot up...see if it eventually comes up...I will keep reading for a solution other than the two here...and will post as soon as I find one...
Unfortunately, Acer do not have a good fix for most of their computer problems....
~~Jasta~~
Mar 29, 2008 | Acer Aspire 5610 Notebook
Korg PA800 61-Key Professional Arranger Keyboard with Speakers Logo
167 people viewed this question
Top Korg Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Korg Audio Player and Recorder Expert? Answer questions, earn points and help others
