SOURCE: Siemens Sx66 Pda phone- not responding for hard reset-
Hello, Did my solution fix your SX66 problem?
SOURCE: HTC Touch screen not responding!
This is a common problem with many touch screen phones. There are about three reasons this can happen that I know of:
1. Hardware issue. Needs to go in for repair. Hopefully under warranty still.
2. Needs to be re-flashed with the OEM ROM. This is not likely, since you've already Hard Reset, but worth a try.
3. The EASIEST and FIRST thing to check is to run a 'business card' around the edge of the screen between the case and screen. Dirt or other objects can easily get wedged into that area and hold the screen pressed down. This would prevent a press from any other area of the screen. Also, a screen protector that has shifted might cause this. Hopefully this is it, as it's a simple fix!
SOURCE: HTC P3300 does not ON
Apologize for the delay in respose, was having a technical glitch at my end too. Well, if the phone is under one year manufacturer warranty , i would advice to take it in for repairs.
If the warranty is void , try hard reseting the phone ...caution before you do hard reset , it would delete all contacts and files that you saved on it after you got the phone.
Refer owners manual on how to reset the phone . If you donot have the same with , kindly lemme know
Thanks
proton
SOURCE: How do I reset my htc 8925?
Press and hold both soft-keys [they look like minus signs] while putting a paper-clip or something in the reset hole located near the usb port.
SOURCE: HTC TyTn front buttons not working
Please see and try:
http://www.4winmobile.com/forums/htc-hermes/10597-easy-fix-those-non-working-hardware-keys.html
