You might want to contact your local Aerus franchise. They could send someone out to take a look for you. Sometimes our visits end up costing you nothing because of what we find. It could be the board but it could be other things as well. A wire, a switch. A bad motor. They are trained to assist you.You might want to contact your local Aerus franchise. They could send someone out to take a look for you. Sometimes our visits end up costing you nothing because of what we find. It could be the board but it could be other things as well. A wire, a switch. A bad motor. They are trained to assist you.
You can't post conmments that contain an email address.
Your machine is still under warranty if you purchased it new (5 years). Take it to the shop you purchased it from (Aerus Electrolux), or call them for free pick up, and ask them to repair it. The boards do go bad occassionally. It could also be the switch, but can't be sure without taking a look at it and testing it.
The warranty is good only if the vacuum was purchased from an authorized Aerus Electrolux store or representative. Take your copy of the contract in with you.
Some models have an on/off switch on the power unit itself. This switch is used to turn your power unit on when you are right at the machine.
If there is no switch on the power unit, unplug your power unit from the wall socket, look for two low voltage wires coming out of the power unit. These two low voltage wires are usually either attached with terminals or are tied to two wires coming out with plastic screw on wire caps. Disconnect the 2 low voltage wires. Plug your power unit back in. If the power unit does not come back on then yes, the problem is most likely a short in the outlet wiring. If the power unit still comes on with the 2 low voltage wires unattached, then the problem is in the internal circuitry of the power unit, usually a relay or some units have a circuit board with relay, circuit breaker and other components on it. The relay or circuit board will have to be replaced.
It's a little difficult to check for a short if you have multiple outlets, but if you've recently done some renovations you might start checking in that area.
TRY JUMPING THE CENTRAL VAC INLET WIRES AT WALL! IF COMES ON SOMETHING IS MISSING ON HOSE TO WALL CONNECTION. MOST HAVE A METAL RING TO ACTIVATE THE INLET DOOR WHEN HOSE IS CONNECTED.
Please clarify that we are talking about the central vac LED/switch panel panel and plugging it into a 110 V wall receptacle. If I understand when you unplug from the power source ,then plug back in the green LED comes on, looking normal ? But when you manually activate the switch on the motor housing of the vac itself the vac does not start and the LED goes out, so no green or red LED at that point? If this is the case , Kenmore CV's built approx 5 years ago (MADE by EUREKA) and prior had a circuit board with attached cord (as opposed to detachable) which was prone to relay failure. There were several symptoms, most common was that the relay on that switch panel /circuit board would fuse on and the vac would continue to run when the hose was detached from the wall.However some I worked on from that era had exactly the same symptom you describe. If your unit is between 5 and 10 years old and this sounds accurate, you can unscrew this curved side panel relay with one philips screw. Inside on the PCB will be an L shaped black or white 24volt relay, generally rated at 10 amps. The replacement board or relay will be rated at least 24V/ 15 amps or more. If you can isolate your motor and test it separtely with a power cord or meter , the realy/board will be the only control componnet left. If you have a small tipped soldering IRON, not a gun, you can generally find a replacement relay to rebuild the board for about $6 at an electronics parts store. Otherwise you will need to replace the control board itself, anywhere form $45 to $70 plus service call if you have a tech come out to the house, and the tech will just unscrew , detach wires and replace the board, no repair , approx 15 minutes work. This will likely cost over $100. Please post back with your results
I would try to remove the inlet from the wall and tighten the screws that the low voltage wires connect to. If that doesn't work I would buy a new inlet. They are very easy to change out and relatively inexpensive. The inlets are readily available online.
This sounds like a relay sticking on the control board inside the unit. The only other thing I've seen cause this, would be a short in your low voltage wiring. I had a service call where the wires were laid across the top of metal studs and the insulation had been damaged to the point that the wires would short out on the stud. To be sure it's not something in your wiring, disconnect the low voltage wires from the unit while it's "stuck" running. If it continues to run, then have your control board replaced. This is a somewhat common problem on these units. Good Luck!
Is there a small LED light illuminated where the low voltage wires connect to the main unit? There may be a small rubber boot covering the connection and the light. Just slide it back, and there should be a green LED light if the unit has power. If the LED is not on, there is no power to the unit (tripped breaker, plug came loose from electrical outlet, etc.) If LED is illuminated, short across the pins where the low voltage wires connect to the main unit. (These will be small 18-22 gauge wires, not the larger electrical cable!) You can do this with a coin. (Don't worry, it's just 24 volts and you won't even feel it) The unit should come on. If it doesn't, and you have light from the LED, then it's probably the relay on the board inside the unit, or the motor. Good Luck!
There is a relay board on the unit (where the dirt goes) There are two small wires that connect and usually a switch near by. This switch has an Auto and Manual setting. If set to manual the unit will run all the time or until set back to Auto. If it is set to Auto and is still running, unplig the two small wires. They are sometimes on screw terminals behind a round plactic cover. It does not matter which terminal the wires go back on just one on each.
If the unit turns off the problem is in the wire running to each valve or a paper clip is shorting across the pins of a wall outlet. (something like this).
If the unit does not turn off once the wires are removed, the relay in the unit is stuck closed and will need to be replaced. Time to call a pro unless you have good electrical skills.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113669&thid=657359 Electrolux Centralux Posted by Brucebob on Jun 09, 2008 I have an Electrolux Centralux. When I plug the hose in at one of the wall outlets the motor will not start. If I go to the motor and slap the unit it will start.....then...it will not stop unless I unplug the power cord to the motor. If I plug the power cord back in, the unit will not restart until I slap the motor unit again. The unit has only been used 20 - 30 times. Any suggestions?Thanks, Bruce Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You may have a bad inlet or household outlet; try all the inlets in the house too. But it sounds to me that your carbon brushes are dirty and need cleaning or replacing would be my 1st suggestion. Take a good wire brushes or pipe cleaner to clean the inside of the carbon brushes if they stick then replace them. So if the unit has only been used 20 to 30 times I would suggest some one to come and look @ it who did the install because it is still under a factory warranty and if you start messing with things you will void the factory warranty on the motor. And then if it is the motor for some reason then the factory or vendor will eat the cost of the repair. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. http://electrolux.com/Customer Service1-800-896-9756 Electrolux Home Care Products – North America P.O. Box 3900Peoria, IL61612 Thanks, Don the Vac Man Go Ahead. Use Us.
