RIM BlackBerry  7290 Logo
M
Melvin Douw Posted on Sep 05, 2016
My blackberry7290 goes on but after a few min it says device error?
My laptop runs for a few min then goes to blue screen memory dump page
hmmm sounds like the computer is facing a problem with the operating system or the hard drive is starting to fail on you
MY philips 42 inch plasma TV model 42pf3320/10 screen goes black after a few mins sometimes. what can i do to fix it???
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
I got an error in my console e73erro
E73: I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices
Sometiems you can fix this with a reflow, but its hit & miss (50/50) with this error, as the actual port may be faulty, but reflowing wont hurt to try, or you can sell it for spare parts on ebay and get another base unit.
If you wanna try to reflow, there is a great 6part video guide on YouTube to view for free. 6 videos from the same fellow, each video is a few mins long, and goes over everything for you.
http://www.youtube.com/user/ohiocitysales#p/u and its free unlike some eBook site.
I actually used the same method to fix over 450 Xbox360 units with no problems at all, barring a few (but i have done nearly 500 so you expect a few problems along the way), you just need a few things though like a heat gun and some thermal paste. sounds hard, but it's very easy once you start!
Hope this helps in some way.
Player stops. H07 appears.
This is a problem with the spindle motor,you can locate where the spindle goes into the motor and spray with wd40 leave for a few mins.
5helpful
3answers
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Mitsubishi WD-62528 error code 45
go to the manufacture site they should tell you what the code means if not try techlore.com
Tom tom 3
This is a battery save setting.
Check settings under Battery Saving Preferences, choose Never Turn Off Screen
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
