Are you referring to something like this?
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.2 25
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.1.0 255.255.255.0 On-link 192.168.1.2 281
192.168.1.2 255.255.255.255 On-link 192.168.1.2 281
192.168.1.255 255.255.255.255 On-link 192.168.1.2 281
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.1.2 281
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.1.2 281
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
192.168.1.2 0.0.0.0 255.255.255.255 UH 0 0 0 eth1
10.10.10.1 0.0.0.0 255.255.255.192 U 0 0 0 eth0
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
10.0.0.0 10.14.42.129 255.0.0.0 UG 0 0 0 eth0
0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 eth1
SOURCE: Routing vlans on 3com switch 4500
i can't set ip address over 4 vlans. the 3com switch 4500 always give error message "there's not enough routing resources available".please help....
SOURCE: I have a 3com 4500
From your scenario what i guess is the two 5500's (A&B) are connected to each other also. Thats why the link between B&4500 is remaining down due to STP ( to avoid Network loop).
Please correct me if I am wrong.
What is the status of the link connecting 4500 to 5500 B when 500A is active and when 5500A is down .
If you are running STP i will suggest you to wait for 2 minutes after 5500A goes down and STP will be recalculated and the link connecting to 5500B will become active and then the route will also become active.
Best regards
At this point it is enough to count the lines in show ip bgp filter-list 1 output to count the routes that are originated in the local AS at R1 WS-C3560X-24P-L Price and received on R2 and installed on R2.
Original comes from http://switch.blogcindario.com/
