SOURCE: Maytag washer won't spin out
Before you try to take the panel apart to remove the timer you need to check that the electrical connections to the pump are o.k. and whether the pump is getting power when it's time to drain. If you have to replace the timer you need to take the back panel off first.
SOURCE: maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
SOURCE: wont drain,spin,or agitate
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
SOURCE: Maytag Centennial washer agitates when
Don't know what it is , but the 3 guys above me are wrong
