This is tech side of programming and not Admin, if you don't know config password or how to program then call a tech. If you do know then: First find out what line #, do F*0 then press the button and note the full number on the display. i.e. Line 5 in programming is Line 005, 025 or 031 depending on software version.
Sets/LineAccess/LineAssignment/Show line ***/Change to Appear Only or Not Assigned.
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Enter Feature **2663444
Search through General Options until you find Ringing options.
Type in the extension number of your personal office.
scroll to line 4 choose turn ringer to off, and rls! Let me know if you need clarification on how to find Ringers in General Options.
Is set relocation on?
If not then probably what has happened is that the new station port does not have ringing programming of the old port.
if you know how to do this go into riging programming of the set and activate it
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
If you are and know how to get into the admin programming of it, then you go to the line programming and select the number of rings before the vmail system answers.
set the rings to "3", then the lines should ring 3 times on your phone, then on the 4th ring the vmail system will answer
It's RINGING now! I followed the Set Programming instruction in our manual. It's in Configuration 3-21. It's a very old old Operator guide. I am trying to find it online. In the mean time you can use the M7208 Phone Adminitration Overlay over the keys and program your phone by pressing Feature **266344 Here is a link to the overlay Good Luck.
I need more information. When calls come in, does the triangles appear on the phones you want to pick up? Do you have all the lines on the phones? Is sounds like you want only the "ringing sound" to happen on your phone, but have it appear on the others. Is this correct??
