You must disconnect the engine from the motor mounts and exhaust and remove anything that will interfere with raising it off the mounts as high as possible, once it is off the mounts and raised the pan can be removed. I read this at a owners site from a guy who has done the job, he said it is a real pain in the rear but doable.
SOURCE: Oil pan removal problems on my 89 F-350 w/7.3L Diesel
remove the cross member then you can drop the pan
SOURCE: 98 chevy s-10 2wd is it possible to change the oil
Yes it is possible but you will have to get about six inches of clearance so the pan will clear the oil pump pickup
SOURCE: Is there ANY way to change the oil pan gasket on a S10...
Remove motor mount bolts and rear transmission crossmember bolts or nuts,suppport engine/trans. see if u have enough clearance between pan and axle remove pan. if not, split the exh away from the manifolds. worth a try
SOURCE: Oil pan gasket replacement on a 2005 Escape
YEP YOU HAVE TO REMOVE FLEXIBLE EXHAUST PIPE.AND DISCONNECT THE OXYGEN SENSOR.
SOURCE: Replace Oil Pump Can it be doen without pulling
not really u will have to remove motor mounts jack up engine and move or remove components to remove the oil pan ur biggest problem is ur limited clearance between oil pan and frame cross member as well as lying on back under van
