Computers & Internet Logo
muhammad Posted on Aug 31, 2016
How to fix this issue of HTC pu10 align screen
1 Related Answer
Anonymous
  • Posted on Aug 24, 2009
SOURCE: ican not align screen my htc touch hd
I can not align screen my touch HD
1helpful
I-mate JASJAR pu10 Smartphone windows mobile 5.0 data mixing, how can I get same windows to install?
...mda pu 10 to connect t computer hi where can i find the driver so can connect my foon"mda pu10" so ican take...
5helpful
My htc tytn ii stays on align screen after hard reset what should i do help me please
Have you completed the alignment procedure? The phone will not let you progress until alignment is complete.
Once complete, click "OK" in the top right corner to exit the screen.
If this has fixed your problem then please take a moment to rate my answer, if not then please give more detail about what's happening and I'll try to assist you further. I don't have your exact model, but have owned a few other HTC models using both Windows Mobile (like yours) and Android operating systems so I'm confident that if the problem has a fix I can help you to find it..
2helpful
2answers
Problem of align screen htc p3300
Try Settings>General>AlignScreen
2helpful
2answers
Htc touch diamond non responsive align screen after hard reset
pda requests align of screen until you do it, if you cannot pass through aligning, you could have you digitizer broken, than you should put it to service
Hod do i align my screen
Go to settings, then go to system and scrool down until u see aligh screen or you can do the g-sensor. They both fix screen problems.
9helpful
Ican not align screen my htc touch hd
3helpful
How to fix or escape from htc touch align screen
The quickest way out of the alignment screen is to actually align the screen by pressing the screen whereever the little cross is located on the screen. Or if you don't want to align the screen simpley hit the power button to turn it off and then hit it again to turn it back on.
18helpful
2answers
Screen alignment could not be done
I accidentally click on something and my screen alignment for my HTC mobile phone has run significantly... When I tried to align the screen from the setting, it only write that tap firmly and accurately on the target. the target will continue to move until the screen is aligned. Till now, i tried many times but the alignment is still out
I m having scree on HTC diamond saying : align screen. I dont know what i need to do
actually it a hardware related issue if u are stuck at alignment screen then u have to go and replace the handset , actually Touch panel is faulty and it needs to be replaced these days touch panels fitted with these new devices are giving much problems and Company's are queit on this just go and change it in warranty , try aligning like 5 times atleast with some pointed thing tkae care if it stucks then there is nothing u can do jus cry for replacement
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
