Only flush using normal engine oil as flushing oil is not good for the engine
If you want to flush it out , the best oil to use is diesel oil 20w-40 as the detergents in that oil will clean out the engine
change the oil filter and then change it again in 2,000 miles , then again as the oil will remove sludge that will be caught in the filter
change the filter one last time , depending on the oil color on the dip stick
as for the smoke at the end and the turbo, that could be from a failing turbo seal allowing oil into the exhaust side
Have it checked out at a specialist turbo repair shop
