SOURCE: KLH R5100
in stero mold only 4 speeker will work ftr ftl center sub u need a sound sliter cornet it to the tow frount that what i did
SOURCE: connect R5100 to DVR/Monitor
use component audio to the HDTV and optical audio to your KLH reciever. The component and optical are always active at the same time. I work for TWC if you have more questions.
SOURCE: Don't have a manual or the remote for KLH audio
There should be numbered buttons on the receiver.Set the channel to what you want to preset,then press and hold down the numbered button you want.The sound will probably go away for a couple of seconds but when it comes back on the channel is preset.If you press the band button while you're already on FM and it goes to another FM,you can also preset more channels for FM.There should only be one AM band,then it will switch back to FM.
Good luck! Greg
SOURCE: want manual for Klh R5100 receiver where do I get one?
You can get the manual from manualfox.com
