Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Can you tell exactly what is on the screen please. The system error focus is not supposed to be an real error that is displayed on your camera.
"System error" is possible. But if switching of and a few moments later switching on does not change the error on the dis[lay, you should contact a Panasonic certified repair centre.
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it ((browse)) select the file/folder where you want to save it (my pictures) most common hope this helps
Two possible problems have happened. What does the display show when the camera trys to power on? If it says error on the top of the display error 31 you have a stuck lens barrell. If it shows nothing you may have broken the display. Let me know what happens I will answer back.
hi jowens,
this prob usually happens when u format ur mp3 player when it was plugged on to ur computer...so better delete all d entries in d mp3 player...now insert d software cd given with ur music player, install d software properly and now transfer music to ur mp3 player.... now ur problem ll be sorted out.
Note: everytime u format ur mp3 player, u get dis problem....so again install a software cd and synchronize with the computer again, before transferring music...
