I have bizhub Printer C284. and at first was giving an error C-FA14. I update a new firmware, and after that , it came another error code. C-E002. What can I do to resolv this or what firmware do I have to use?
1. Turn OFF the main power switch and turn it ON again,
and conduct the following setting. [Service Mode] ->
[System 1] -> [Initialization] -> [Data Clear].
I.11.14.8 Initialization-Clear All Data
2 Format hard disk - -
3 Replace the hard disk. - -
4 Replace MFPB
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: bizhub 200 printer
Tray two elevator motor failure. Make sure you dont have anything sitting under the trays and also make sure the trays are level
SOURCE: Error code: 49.2F9D
ok, go to the link to fix your problem--
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
SOURCE: a canon np 7161 with an e002 error code. It is my
ok let me help u on fixing your problem.
mostly this error is in fusing unit and may be due to power disturbance.
first press * (star) then 2 & 8 together again *(star) if succesfully u presed 2&8 together and then *(star) the number 1 (one) will appear in the box [ 1 ] then press 4 then A (automatic exposure) then 412 and finally finnish by pressing the start button/print button the machine will go OFF turn it ON it is now ok. if not start again follow the sequency untill to the step of pressing the start button insted of it press A.
try your best, kibokoyao waiting for your vote.
SOURCE: Error code 2,155,0
It seems that the printer has communication problem with the computer. If you are sure your USB cable is good than it might be the board of the printer is faulty
Testimonial: "Thank you for your assistance. I replaced the 3M cable that is used with the desk top with a 1.8M one. It seems the laptop can't handle the long cable"
SOURCE: bizhub 250 All-In-One Laser Printer: Error code C3451 wont reset using Utility key at s...
• The Fusing Roller Thermistor does not detect
the required temperature within 30 sec. after a
warmup cycle has begun; therefore, the copier
does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
You may have a bad fuser section. Another reset method is a small button located on the right side of the machine under on the scanner section. Locate your network port, then to the left of the port is a small cover that can be removed, behind that cover on the left is a small black button, use a paper clip or ball point pen and press the button, this will do a machine reset. When the operation panel abort starts to load hit the number 3 button, you should see a small back circle in the top right of the operation panel. This will give you the option to do a trouble reset.
If this does not work you will need a technician to come out and replace the fuser section, make sure they bring one with them so they don't have to reschedule and come back.
