Daewoo DWD-F1011 IE error code
I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code IE. Any idea what that might be?
replace the water shutoff solenoid valve assembly
in the mean time when the machine is full turn the tap off
change the hot water hose over to the cold water tap and use the hot water solenoid button
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
When you hear that macinhe is beeping and giving 1E code, turn it off and make sure that water feeder is turned on and that it can feed water into the machine, turn it back on and start your program, it should be fine :) .... Good Luck....
I have DAEWOO Washing machine DWD F1011. Whithin few years water started leaking through the drive shaft and ball bearing damaged. I need service manual for how to change the ball bearing or is there any repairer in Heliopolis, Cairo area?
if this is a fridgidaire washer, I guess it's a clogged coin catcher. You have remove the front access panel and clean it out. I am working on that now.
