Question about Leisure Kitchen Ranges
Why won't my Leisure CM10FRK range fan oven heat up?
    Top Expert:
  • Leisure Master
  • 64,222 Answers
Heating element might have burnt thru and needs replaced .
Posted on Aug 29, 2016
SOURCE:
Rangemaster 55 leisure. My timer has stopped working
Hi Stella,
i am sorry for you, but you can forget repairing the timer.
You can replace it of course.
You do not need the timer to operate the oven.
For that you need to bypass the timer. The clock will stay working normally.
Although the 55 is smaller then the 110, the working of the clock should be the same.
Net link will give you more information and I hope you will fin the solution there.
Kind regards and a good weekend, Dik
Leisure Rangemaster 110 Electric Range Cooker How to bypass
Feb 28, 2017 | Rangemaster LEISURE 55 & 110 FAN OVEN...
My gourmet classic leisure cooker has a noisy fan. What can I do?
Hello CAROL ROSA,
If it is NEW... TAKE IT BACK.
ELSE... (replace the fan).
Post the actual model number to see if
we need to look for 'parts' (USA) or "spares" (rest of the world)...
Together we can get this
'FIXED' (USA) or "sorted" (rest of the world)...
http://www.harveynorman.ie/home-appliances/cooking-appliances/range-cookers/leisure-gourmet-classic-oven-grb6cvr.html
Aug 30, 2016 | Kitchen Appliances - Others
I have a leisure range cooker. model number CMTF99R.The oven RHSis not Heating up. the fan is working and the thermostat light is coming on.
Check for voltage at the element, could be a hi-limit thermostat or a failure at the control board.... You may find you are missing one leg (half) of the 240VAC required to power the elements
Jul 31, 2016 | Leisure Range 90 CMTF95C Cream 900 mm Dual...
Main oven not no heat.thought maybe heating element. tried to take element out from inside oven but seem I may need to take back cover off as it seems the two screws on one side come in from there.
yes your doing fine, usually heating element are sturdy and seldom busted. try to follow the wiring inside and locate the thermal fuse that is installed inline with the wiring,have it replaced
Sep 03, 2015 | Leisure GRB6CVR Electric Cooker with...
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Have a Leisure roma 100 cooker model number RM10FRS main fan oven not heating need a service manual to find out how to get at heating element to see if needs replacing.
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
Jul 05, 2010 | Kitchen Ranges
Leisure levc66x - bang from fan oven blew tripswitch - fan operating but no heat - top oven ok - 18 month old unit
It appears that the ring element for the oven has burnt out and will need replacing.
Hope this helped.
May 13, 2010 | Ovens
Having problems with fan assisted oven on leisure roma 100 cooker, it doesnt seem to work everything else seems to work fine, Can anyone help me
Often these fan assisted type ovens have a safety that keeps th fan off if it believes the door is open. Look for uneven door closing or cracks in the door to frame closure. Is this a commercial convection oven?
May 08, 2009 | Kitchen Ranges
Kitchen Ranges Logo
63 people viewed this question
Top Leisure Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
Chuck Graybill
ray gallant
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
